Variable speed limits control in an urban road network to reduce environmental impact of traffic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Contrôle des limitations de vitesse variables dans un réseau routier urbain pour réduire l'impact environnemental du trafic
The problem of improving traffic sustainability and traffic efficiency in an urban road network, by implementing variable speed limits (VSL), is addressed in this paper. A nonlinear model predictive control (NMPC) design based on a first-order macroscopic traffic flow model is proposed for the speed limits optimization in each segment of the road network. Simulation results show the effectiveness of the proposed control approach, compared to reference cases in which the speed limits are constantly set to 30 km/h or 50 km/h. In the particular case of congested traffic conditions, the controller is capable of reducing both energy consumption and travel time, without delaying users waiting at the network boundaries.
Othman et al., Variable Speed Limits.pdf (373.38 Ko) Télécharger le fichier
hal-02511893 , version 1 (19-03-2020)
Bassel Othman, Giovanni de Nunzio, Domenico Di Domenico, Carlos Canudas de Wit. Variable speed limits control in an urban road network to reduce environmental impact of traffic. ACC 2020 - American Control Conference, Jul 2020, Denver (online), United States. pp.1-6, ⟨10.23919/ACC45564.2020.9147617⟩. ⟨hal-02511893⟩
253 Consultations
297 Téléchargements
