Hydrodynamic limit for a chain with thermal and mechanical boundary forces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We prove the hydrodynamic limit for an harmonic chain with a random exchange of momentum that conserves the kinetic energy but not the momentum. The system is open and subject to two thermostats at the boundaries and to external tension. Under a diffusive scaling of space-time, we prove that the empirical profiles of the two locally conserved quantities, the volume stretch and the energy, converge to the solution of a non-linear diffusive systems of conservative partial differential equations.
openflip.pdf (327.11 Ko) Télécharger le fichier
hal-02538469 , version 1 (09-04-2020)
hal-02538469 , version 2 (18-04-2020)
  • HAL Id : hal-02538469 , version 1
Tomasz Komorowski, Stefano Olla, Marielle Simon. Hydrodynamic limit for a chain with thermal and mechanical boundary forces. 2020. ⟨hal-02538469v1⟩
189 Consultations
233 Téléchargements
