Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Journal articles
Hydrodynamic limit for a chain with thermal and mechanical boundary forces
Abstract : We prove the hydrodynamic limit for an harmonic chain with a random exchange of momentum that conserves the kinetic energy but not the momentum. The system is open and subject to two thermostats at the boundaries and to external tension. Under a diffusive scaling of space-time, we prove that the empirical profiles of the two locally conserved quantities, the volume stretch and the energy, converge to the solution of a non-linear diffusive systems of conservative partial differential equations.
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-02538469
Contributor : Marielle Simon Connect in order to contact the contributor
Submitted on : Saturday, April 18, 2020 - 3:53:49 PM
Last modification on : Friday, April 1, 2022 - 3:55:46 AM
File
KOS-last-version.pdf
Identifiers
Citation
Tomasz Komorowski, Stefano Olla, Marielle Simon. Hydrodynamic limit for a chain with thermal and mechanical boundary forces. Electronic Journal of Probability, Institute of Mathematical Statistics (IMS), 2021, 26, ⟨10.1214/21-EJP581⟩. ⟨hal-02538469v2⟩
Share
Metrics
Record views
161
Files downloads
214
