Polygonal Building Segmentation by Frame Field Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
While state of the art image segmentation models typically output segmentations in raster format, applications in geographic information systems often require vector polygons. We propose adding a frame field output to a deep image segmentation model for extracting buildings from remote sensing images. This improves segmentation quality and provides structural information, facilitating more accurate polygonization. To this end, we train a deep neural network, which aligns a predicted frame field to ground truth contour data. In addition to increasing performance by leveraging multi-task learning, our method produces more regular segmentations. We also introduce a new polygonization algorithm, which is guided by the frame field corresponding to the raster segmentation.
archive.pdf (10.23 Mo) Télécharger le fichier
hal-02548545 , version 1 (27-04-2020)
hal-02548545 , version 2 (31-03-2021)
  • HAL Id : hal-02548545 , version 1
Nicolas Girard, Dmitriy Smirnov, Justin Solomon, Yuliya Tarabalka. Polygonal Building Segmentation by Frame Field Learning. 2020. ⟨hal-02548545v1⟩
Collections
OPAL
364 Consultations
393 Téléchargements
