Robust Detection of the North-West African Upwelling From SST Images
Analysis and study of coastal upwelling using sea surface temperature (SST) satellite images is a common procedure because of its coast effectiveness (economic, time, frequency, and manpower). Developing on the Ekman theory, we propose a robust method to identify the upwelling regions along the northwest African margin. The proposed method comes to overcome the issues encountered in a recent method devoted for the same purpose and for the same upwelling system. Afterward, we show how our method can serve as a framework to study and monitor the spatio-temporal variability of the upwelling phenomenon in the studied region.
