Abstract : The paper is devoted to stability analysis of homogeneous time-delay systems applying the Lyapunov-Krasovskii theory, and a generic structure of the functional is given that suits for any homogeneous system of non-zero degree (and can also be used for any dynamics admitting a homogeneous approximation). The obtained stability conditions are utilized to evaluate the domain of attraction for the delayed twisting control algorithm.
