Analysis of robustness of homogeneous systems with time delays using Lyapunov-Krasovskii functionals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2020
The paper is devoted to stability analysis of homogeneous time-delay systems applying the Lyapunov-Krasovskii theory, and a generic structure of the functional is given that suits for any homogeneous system of non-zero degree (and can also be used for any dynamics admitting a homogeneous approximation). The obtained stability conditions are utilized to evaluate the domain of attraction for the delayed twisting control algorithm.
Homo_Robust_LKF.pdf (402.74 Ko) Télécharger le fichier
hal-02614951 , version 1 (21-05-2020)
Denis Efimov, Alexander Aleksandrov. Analysis of robustness of homogeneous systems with time delays using Lyapunov-Krasovskii functionals. International Journal of Robust and Nonlinear Control, inPress, ⟨10.1002/rnc.5115⟩. ⟨hal-02614951⟩
47 Consultations
192 Téléchargements
