Equilibrium Configurations For Nonhomogeneous Linearly Elastic Materials With Surface Discontinuities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annali della Scuola Normale Superiore di Pisa, Classe di Scienze Année : 2023
We prove a compactness and semicontinuity result that applies to minimisation problems in nonhomogeneous linear elasticity under Dirichlet boundary conditions. This generalises a previous compactness theorem that we proved and employed to show existence of minimisers for the Dirichlet problem for the (homogeneous) Griffith energy.
MinimisationGSBDpRevisedBN.pdf (473.64 Ko) Télécharger le fichier
hal-02667936 , version 1 (31-05-2020)
hal-02667936 , version 2 (07-10-2021)
Antonin Chambolle, Vito Crismale. Equilibrium Configurations For Nonhomogeneous Linearly Elastic Materials With Surface Discontinuities. Annali della Scuola Normale Superiore di Pisa, Classe di Scienze, 2023, XXIV (3), pp.1575-1610. ⟨10.2422/2036-2145.202006_002⟩. ⟨hal-02667936v2⟩
100 Consultations
66 Téléchargements
