Stretch-Based Hyperelastic Material Formulations for Isogeometric Kirchhoff-Love Shells with Application to Wrinkling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer-Aided Design Année : 2021
Hugo M. Verhelst
  • Fonction : Auteur
  • PersonId : 1078870
Matthias M. Möller
  • Fonction : Auteur
  • PersonId : 1074457
Henk J den Besten
  • Fonction : Auteur
  • PersonId : 1078871
Mirek L. Kaminski
  • Fonction : Auteur
  • PersonId : 1078872
Modelling nonlinear phenomena in thin rubber shells calls for stretch-based material models, such as the Ogden model which conveniently utilizes eigenvalues of the deformation tensor. Derivation and implementation of such models have been already made in Finite Element Methods. This is, however, still lacking in shell formulations based on Isogeometric Analysis, where higher-order continuity of the spline basis is employed for improved accuracy. This paper fills this gap by presenting formulations of stretch-based material models for isogeometric Kirchhoff-Love shells. We derive general formulations based on explicit treatment in terms of derivatives of the strain energy density functions with respect to principal stretches for (in)compressible material models where determination of eigenvalues as well as the spectral basis transformations is required. Using several numerical benchmarks, we verify our formulations on invariant-based Neo-Hookean and Mooney-Rivlin models and with a stretch-based Ogden model. In addition, the model is applied to simulate collapsing behaviour of a truncated cone and it is used to simulate tension wrinkling of a thin sheet.
paper.pdf (2.49 Mo) Télécharger le fichier
hal-02890963 , version 1 (06-07-2020)
hal-02890963 , version 2 (31-05-2021)
Hugo M. Verhelst, Matthias M. Möller, Henk J den Besten, Angelos Mantzaflaris, Mirek L. Kaminski. Stretch-Based Hyperelastic Material Formulations for Isogeometric Kirchhoff-Love Shells with Application to Wrinkling. Computer-Aided Design, 2021, 139 (103075), ⟨10.1016/j.cad.2021.103075⟩. ⟨hal-02890963v2⟩
335 Consultations
971 Téléchargements
