Fully discrete loosely coupled Robin-Robin scheme for incompressible fluid-structure interaction: stability and error analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerische Mathematik Année : 2022
We consider a fully discrete loosely coupled scheme for incompressible fluid-structure interaction based on the time semi-discrete splitting method introduced in [Burman, Durst & Guzmán, arXiv:1911.06760]. The splittling method uses a Robin-Robin type coupling that allows for a segregated solution of the solid and the fluid systems, without inner iterations. For the discretisation in space we consider piecewise affine continuous finite elements for all the fields and ensure the inf-sup condition by using a Brezzi-Pitkäranta type pressure stabilization. The interfacial fluid-stresses are evaluated in a variationally consistent fashion, that is shown to admit an equivalent Lagrange multiplier formulation. We prove that the method is unconditionally stable and robust with respect to the amount of added-mass in the system. Furthermore, we provide an error estimate that shows the error in the natural energy norm for the system is O(√ T (√ ∆t + h)) where T is the final time, ∆t the time-step length and h the space discretization parameter.
paper.pdf (765.75 Ko) Télécharger le fichier
hal-02893444 , version 1 (08-07-2020)
Erik Burman, Rebecca Durst, Miguel Angel Fernández, Johnny Guzmán. Fully discrete loosely coupled Robin-Robin scheme for incompressible fluid-structure interaction: stability and error analysis. Numerische Mathematik, 2022, 151, pp.807-840. ⟨10.1007/s00211-022-01295-y⟩. ⟨hal-02893444⟩
160 Consultations
88 Téléchargements
