Embedding median graphs into minimal distributive ∨-semi-lattices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alain Gély
Amedeo Napoli
It is known that a distributive lattice is a median graph, and that a distributive ∨-semi-lattice can be thought of as a median graph i every triple of elements such that the inmum of each couple of its elements exists, has an inmum. Since a lattice without its bottom element is obviously a ∨-semi-lattice, using the FCA formalism, we investigate the following problem: Given a semi-lattice L obtained from a lattice by deletion of the bottom element, is there a minimum distributive ∨-semi-lattice L d such that L can be order embedded into L d ? We give a negative answer to this question by providing a counter example.
nfMCP2019-gely-al.pdf (505.09 Ko) Télécharger le fichier
hal-02912341 , version 1 (05-08-2020)
  • HAL Id : hal-02912341 , version 1
Alain Gély, Miguel Couceiro, Amedeo Napoli. Embedding median graphs into minimal distributive ∨-semi-lattices. NFMCP 2019 - 8th International Workshop on New Frontiers in Mining Complex Patterns in conjunction with ECML-PKDD 2019, Sep 2019, Wùzburg, Germany. ⟨hal-02912341⟩
57 Consultations
83 Téléchargements
