Finite-Time and Fixed-Time Input-to-State Stability: Explicit and Implicit Approaches - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 2020
The present article gathers the analysis of non-asymptotic convergence rates (finite-time and fixed-time) with the property of input-to-state stability. Theoretical tools to determine this joint property are presented for the case where an explicit ISS Lyapunov function is known, and when it remains in implicit form (e.g. as a solution of an algebraic equation). For the case of finite-time input-to-state stability, necessary and sufficient conditions are given whereas for the fixed-time case only a sufficient condition is obtained. Academic examples and numerical simulations support the obtained results.
_IISSLF-journal-final-hal.pdf (1.11 Mo) Télécharger le fichier
hal-02921837 , version 1 (25-08-2020)
Francisco Lopez-Ramirez, Denis Efimov, Andrey Polyakov, Wilfrid Perruquetti. Finite-Time and Fixed-Time Input-to-State Stability: Explicit and Implicit Approaches. Systems and Control Letters, 2020, 144, ⟨10.1016/j.sysconle.2020.104775⟩. ⟨hal-02921837⟩
66 Consultations
216 Téléchargements
