Exponential Synchronization of Nonlinear Oscillators Under Sampled-Data Coupling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2020
This paper presents a novel approach towards synchronization analysis of nonlinear oscillatory systems, bidi-rectionally coupled via a networked communication channel. The system under consideration is a two-agent nonlinear system, under the constraint that information is transmitted between the two systems using a sampled-data communication strategy that could be periodic or aperiodic. The networked system dynamics is remodelled as a feedback-interconnection of a continuous-time system, and an operator that accounts for the communication constraints. By studying the properties of this feedback-interconnection in the framework of dissipativity theory, we provide a novel criterion that guarantees exponential synchronization. The provided criterion also aids in deciding the trade-off between a bound on the sampling intervals, the coupling gain, and the desired transient rate of synchronization. Finally, the theoretical results are illustrated using a two-agent Fitzhugh-Nagumo system.
root.pdf (1.42 Mo) Télécharger le fichier
hal-02934258 , version 1 (09-09-2020)
hal-02934258 , version 2 (26-10-2020)
  • HAL Id : hal-02934258 , version 1
Jijju Thomas, Erik Steur, Christophe Fiter, Laurentiu Hetel, Nathan van de Wouw. Exponential Synchronization of Nonlinear Oscillators Under Sampled-Data Coupling. [Technical Report] Centrale Lille; TU Eindhoven. 2020. ⟨hal-02934258v1⟩
108 Consultations
172 Téléchargements
