New interface
Reports (Technical report)
Exponential Synchronization of Nonlinear Oscillators Under Sampled-Data Coupling
Abstract : This paper presents a novel approach towards synchronization analysis of nonlinear oscillatory systems, bidi-rectionally coupled via a networked communication channel. The system under consideration is a two-agent nonlinear system, under the constraint that information is transmitted between the two systems using a sampled-data communication strategy that could be periodic or aperiodic. The networked system dynamics is remodelled as a feedback-interconnection of a continuous-time system, and an operator that accounts for the communication constraints. By studying the properties of this feedback-interconnection in the framework of dissipativity theory, we provide a novel criterion that guarantees exponential synchronization. The provided criterion also aids in deciding the trade-off between a bound on the sampling intervals, the coupling gain, and the desired transient rate of synchronization. Finally, the theoretical results are illustrated using a two-agent Fitzhugh-Nagumo system.
Document type :
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-02934258
Contributor : Jijju Thomas Connect in order to contact the contributor
Submitted on : Monday, October 26, 2020 - 4:03:44 PM
Last modification on : Tuesday, November 22, 2022 - 2:26:16 PM
File
root.pdf
Identifiers
  • HAL Id : hal-02934258, version 2
Citation
Jijju Thomas, Erik Steur, Christophe Fiter, Laurentiu Hetel, Nathan van de Wouw. Exponential Synchronization of Nonlinear Oscillators Under Sampled-Data Coupling. [Technical Report] Centrale Lille; TU Eindhoven. 2020. ⟨hal-02934258v2⟩
Share
Metrics
Record views
92
Files downloads
154
