General-purpose kernel regularization of boundary integral equations via density interpolation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Methods in Applied Mechanics and Engineering Année : 2021
This paper presents a general high-order kernel regularization technique applicable to all four integral operators of Calder\'on calculus associated with linear elliptic PDEs in two and three spatial dimensions. Like previous density interpolation methods, the proposed technique relies on interpolating the density function around the kernel singularity in terms of solutions of the underlying homogeneous PDE, so as to recast singular and nearly singular integrals in terms of bounded (or more regular) integrands. We present here a simple interpolation strategy which, unlike previous approaches, does not entail explicit computation of high-order derivatives of the density function along the surface. Furthermore, the proposed approach is kernel- and dimension-independent in the sense that the sought density interpolant is constructed as a linear combination of point-source fields, given by the same {Green's function} used in the integral equation formulation, thus making the procedure applicable, in principle, to any PDE with known {Green's function}. For the sake of definiteness, we focus here on Nystr\"om methods for the (scalar) Laplace and Helmholtz equations and the (vector) elastostatic and time-harmonic elastodynamic equations. The method's accuracy, flexibility, efficiency, and compatibility with fast solvers are demonstrated by means of a variety of large-scale three-dimensional numerical examples.
S0045782521000396.pdf (11.98 Mo) Télécharger le fichier
hal-02964015 , version 1 (10-03-2023)
Paternité - Pas d'utilisation commerciale
Luiz Maltez Faria, Carlos Pérez-Arancibia, Marc Bonnet. General-purpose kernel regularization of boundary integral equations via density interpolation. Computer Methods in Applied Mechanics and Engineering, 2021, 378, pp.113703. ⟨10.1016/j.cma.2021.113703⟩. ⟨hal-02964015⟩
80 Consultations
24 Téléchargements
