A Unified Framework for Double Sweep Methods for the Helmholtz Equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2023
We consider sweeping domain decomposition preconditioners to solve the Helmholtz equation in the case of stripwise domain decomposition with or without overlaps. We unify their derivation and convergence studies by expressing them as Jacobi, Gauss-Seidel, and Symmetric Gauss-Seidel methods for different numbering of the unknowns. The proposed framework enables theoretical comparisons between the double sweep methods in [Nataf and Nier (1997), Vion and Geuzaine (2018)] and those in [Stolk (2013, 2017), Vion and Geuzaine (2014)]. Additionally, it facilitates the introduction of a new sweeping algorithm. We provide numerical test cases to assess the validity of the theoretical studies.
main (1).pdf (3.44 Mo) Télécharger le fichier
main.pdf (3.47 Mo) Télécharger le fichier
hal-02964033 , version 1 (26-10-2020)
hal-02964033 , version 2 (28-01-2021)
hal-02964033 , version 3 (16-10-2022)
hal-02964033 , version 4 (04-12-2023)
Nacime Bouziani, Frédéric Nataf, Pierre-Henri Tournier. A Unified Framework for Double Sweep Methods for the Helmholtz Equation. Journal of Computational Physics, 2023, 490, pp.112305. ⟨10.1016/j.jcp.2023.112305⟩. ⟨hal-02964033v4⟩
278 Consultations
123 Téléchargements
