A polytopic strategy for improved non-asymptotic robust control via implicit Lyapunov functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Hybrid Systems Année : 2020
This paper is concerned with finite-and fixed-time robust stabilization of uncertain multi-input nonlinear systems via the implicit Lyapunov function method. Instead of splitting the system into a linear nominal model and an additive perturbation which gathers nonlinearities, parametric uncertainties , and exogenous disturbances, the methodology hereby proposed preserves some nonlinear terms in the nominal system via an exact polytopic representation which leads to design conditions in the form of linear matrix inequalities. As a result, feasible solutions are found where former approaches fail; these solutions have more accurate settling-time estimates with reduced control effort. The corresponding control law includes well-known high-order sliding modes as a particular case. Numerical simulations are provided to illustrate the advantages of the proposal.
_NAHS 2020.pdf (207.53 Ko) Télécharger le fichier
hal-02977692 , version 1 (25-10-2020)
Alan Tapia, Denis Efimov, Miguel Bernal, Leonid Fridman, Andrey Polyakov. A polytopic strategy for improved non-asymptotic robust control via implicit Lyapunov functions. Nonlinear Analysis: Hybrid Systems, inPress, 39, ⟨10.1016/j.nahs.2020.100988⟩. ⟨hal-02977692⟩
100 Consultations
230 Téléchargements
