Complexity of planning for connected agents - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Autonomous Agents and Multi-Agent Systems Année : 2020
We study a variant of the Multi-Agent Path Finding (MAPF) problem in which the group of agents are required to stay connected with a supervising base station throughout the execution. In addition, we consider the problem of covering an area with the same connectivity constraint. We show that both problems are PSPACE-complete on directed and undirected topological graphs while checking the existence of a bounded plan is NP-complete when the bound is given in unary (and PSPACE-hard when the encoding is in binary). Moreover, we identify a realistic class of topo-logical graphs on which the decision problem falls in NLOGSPACE although the bounded versions remain NP-complete for unary encoding.
main.pdf (399.25 Ko) Télécharger le fichier
hal-03003144 , version 1 (13-11-2020)
Tristan Charrier, Arthur Queffelec, Ocan Sankur, François Schwarzentruber. Complexity of planning for connected agents. Autonomous Agents and Multi-Agent Systems, 2020, 34 (2), ⟨10.1007/s10458-020-09468-5⟩. ⟨hal-03003144⟩
43 Consultations
142 Téléchargements
