State-constrained control-affine parabolic problems I: First and Second order necessary optimality conditions
In this paper we consider an optimal control problem governed by a semilinear heat equation with bilinear control-state terms and subject to control and state constraints. The state constraints are of integral type, the integral being with respect to the space variable. The control is multidimen-sional. The cost functional is of a tracking type and contains a linear term in the control variables. We derive second order necessary conditions relying on the concept of alternative costates and quasi-radial critical directions. The appendix provides an example illustrating the applicability of our results.
