State-constrained control-affine parabolic problems I: First and Second order necessary optimality conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Set-Valued and Variational Analysis Année : 2020
In this paper we consider an optimal control problem governed by a semilinear heat equation with bilinear control-state terms and subject to control and state constraints. The state constraints are of integral type, the integral being with respect to the space variable. The control is multidimen-sional. The cost functional is of a tracking type and contains a linear term in the control variables. We derive second order necessary conditions relying on the concept of alternative costates and quasi-radial critical directions. The appendix provides an example illustrating the applicability of our results.
ABKpart1_revision.pdf (455.04 Ko) Télécharger le fichier
hal-03011004 , version 1 (17-11-2020)
  • HAL Id : hal-03011004 , version 1
M Soledad Aronna, J. Frederic Bonnans, Axel Kröner. State-constrained control-affine parabolic problems I: First and Second order necessary optimality conditions. Set-Valued and Variational Analysis, In press. ⟨hal-03011004⟩
31 Consultations
156 Téléchargements
