State-constrained control-affine parabolic problems II: second order sufficient optimality conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2021
In this paper we consider an optimal control problem governed by a semilinear heat equation with bilinear control-state terms and subject to control and state constraints. The state constraints are of integral type, the integral being with respect to the space variable. The control is multidimensional. The cost functional is of a tracking type and contains a linear term in the control variables. We derive second order sufficient conditions relying on the Goh transform.
ABKpart2_revision.pdf (392.44 Ko) Télécharger le fichier
hal-03011027 , version 1 (17-11-2020)
Maria Soledad Aronna, Joseph Frédéric Bonnans, Axel Kröner. State-constrained control-affine parabolic problems II: second order sufficient optimality conditions. SIAM Journal on Control and Optimization, In press, ⟨10.1137/19M1286906⟩. ⟨hal-03011027⟩
70 Consultations
70 Téléchargements
