Optimal bounds and matching networks of fixed degree for frequency varying impedances - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, matching networks of finite degree are computed. Additionally the presented results are compared with the lower fundamental bounds available in the literature. These bounds are used to certify the optimality of the provided matching networks in function of the attained matching tolerance. To illustrate the presented results, two different examples of matching problems are presented.
Electronique
1570603770.pdf (1.32 Mo) Télécharger le fichier
hal-03047706 , version 1 (08-12-2020)
  • HAL Id : hal-03047706 , version 1
David Martinez Martinez, Adam Cooman, Fabien Seyfert, Martine Olivi, Stéphane Bila. Optimal bounds and matching networks of fixed degree for frequency varying impedances. EuCAP 2020 - European Conference on Antennas and Propagation, Mar 2020, Copenhague / Online, Denmark. ⟨hal-03047706⟩
51 Consultations
103 Téléchargements
