Short and squeezed: accelerating the computation of antisparse representations with safe squeezing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Clément Elvira
Antisparse coding aims at spreading the information uniformly over representation coefficients and can be expressed as the solution of an ∞-norm regularized problem. In this paper, we propose a new methodology, coined "safe squeezing", accelerating the computation of antisparse representations. The idea consists in identifying saturated entries of the solution via simple tests and compact their contribution to achieve some form of dimensionality reduction. Numerical experiments show that the proposed approach leads to significant computational gain.
IcasspAntisparse.pdf (251.39 Ko) Télécharger le fichier
hal-03070344 , version 1 (15-12-2020)
Clément Elvira, Cédric Herzet. Short and squeezed: accelerating the computation of antisparse representations with safe squeezing. ICASSP 2020 - 2020 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), May 2020, Barcelona, Spain. pp.5615-5619, ⟨10.1109/ICASSP40776.2020.9053156⟩. ⟨hal-03070344⟩
55 Consultations
136 Téléchargements
