On the Regression and Assimilation for Air Quality Mapping Using Dense Low-Cost WSN - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The use of low-cost Wireless Sensor Networks (WSNs) for air quality monitoring has recently attracted a great deal of interest. Indeed, the cost-effectiveness of emerging sensors and their small size allow for dense deployments and hence improve the spatial granularity. However, these sensors offer a low accuracy and their measurement errors may be significant due to the underlying sensing technologies. The main aim of this work is to reconsider and compare some regression approaches to assimilation ones while taking into account the intrinsic characteristics of dense deployment of low cost WSN for air quality monitoring (high density, numerical model errors and sensing errors). For that, we propose a general framework that allows the comparison of different strategies based on numerical simulations and an adequate estimation of the simulation error covariances as well as the sensing errors covariances. While considering the case of Lyon city and a widely used numerical model, we characterize the simulation errors, conduct extensive simulations and compare several regression and assimilation approaches. The results show that from a given sensing error threshold, regression methods present an optimal sensor density from which the mapping quality decreases. Results also show that the Random Forest method is often the best regression approach but still less efficient than the BLUE assimilation approach when using adequate correction parameters.
Fekih et al_AINA2020.pdf (1.44 Mo) Télécharger le fichier
hal-03084455 , version 1 (21-12-2020)
Mohamed Anis Fekih, Ichrak Mokhtari, Walid Bechkit, Yasmine Belbaki, Hervé Rivano. On the Regression and Assimilation for Air Quality Mapping Using Dense Low-Cost WSN. AINA2020 - 34th International Conference on Advanced Information Networking and Applications, Apr 2020, Caserte, Italy. pp.566-578, ⟨10.1007/978-3-030-44041-1_51⟩. ⟨hal-03084455⟩
300 Consultations
264 Téléchargements
