Pseudospectral methods with PML for nonlinear Klein-Gordon equations in classical and non-relativistic regimes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2022
Two different Perfectly Matched Layer (PML) formulations with efficient pseudospectral numerical schemes are derived for the standard and non-relativistic nonlinear Klein-Gordon equations (NKGE). A pseudo-spectral explicit exponential integrator scheme for a firstorder formulation and a linearly implicit preconditioned finite-difference scheme for a secondorder formulation are proposed and analyzed. To obtain a high spatial accuracy, new regularized Bermúdez type absorption profiles are introduced for the PML. It is shown that the two schemes are efficient, but the linearly implicit scheme should be preferred for accuracy purpose when used within the framework of pseudo-spectral methods combined with the regularized Bermúdez type functions. In addition, in the non-relativistic regime, numerical examples lead to the conclusion that the error related to regularized Bermúdez type absorption functions is insensitive to the small parameter ε involved in the NKGE. The paper ends by a two-dimensional example showing that the strategy extends to the rotating NKGE where the vortex dynamics is very well-reproduced.
PML_for_Klein_Gordon_equation.pdf (1.89 Mo) Télécharger le fichier
hal-03102303 , version 1 (07-01-2021)
Xavier Antoine, Xiaofei Zhao. Pseudospectral methods with PML for nonlinear Klein-Gordon equations in classical and non-relativistic regimes. Journal of Computational Physics, 2022, 448, pp.110728. ⟨10.1016/j.jcp.2021.110728⟩. ⟨hal-03102303⟩
80 Consultations
67 Téléchargements
