Type-generic lambdas - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2022
For the lambda expressions that were introduced in N2734, we propose the addition of auto parameters that can be completed by the arguments (in a function call) or by the parameter types of target function pointer (in a conversion).
n2924.pdf (441.32 Ko) Télécharger le fichier
hal-03106919 , version 3 (12-01-2021)
hal-03106919 , version 4 (10-06-2021)
hal-03106919 , version 1 (14-06-2021)
hal-03106919 , version 2 (02-02-2022)
hal-03106919 , version 5 (06-10-2022)
Paternité
  • HAL Id : hal-03106919 , version 5
Jens Gustedt. Type-generic lambdas: proposal for C23. [Research Report] N2924, ISO JCT1/SC22/WG14. 2022, pp.14. ⟨hal-03106919v5⟩
239 Consultations
204 Téléchargements
