Exact observability properties of subelliptic wave and Schrödinger equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
In this survey paper, we report on recent works concerning exact observability (and, by duality, exact controllability) properties of subelliptic wave and Schrödinger-type equations. These results illustrate the slowdown of propagation in directions transverse to the horizontal distribution. The proofs combine sub-Riemannian geometry, semi-classical analysis, spectral theory and non-commutative harmonic analysis.
Actes TSG v3.pdf (638.98 Ko) Télécharger le fichier
hal-03109787 , version 1 (14-01-2021)
hal-03109787 , version 2 (11-10-2021)
Cyril Letrouit. Exact observability properties of subelliptic wave and Schrödinger equations. 2021. ⟨hal-03109787v2⟩
76 Consultations
128 Téléchargements
