Optimal and sustainable management of a soilborne banana pest - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Mathematics and Computation Année : 2021
In this paper we propose an eco-friendly optimization of banana or plantain yield by the control of the pest burrowing nematode Radopholus similis. This control relies on fallow deployment, with greater respect for the environment than chemical methods. The optimization is based on a multi-seasonal model in which fallow periods follow cropping seasons. The aim is to find the best way, in terms of profit, to allocate the durations of fallow periods between the cropping seasons, over a fixed time horizon spanning several seasons. The existence of an optimal allocation is proven and an adaptive random search algorithm is proposed to solve the optimization problem. For a relatively long time horizon, deploying one season less than the maximum possible number of cropping seasons allows to increase the fallow period durations and results in a better multi-seasonal profit. For regular fallow durations, the profit is lower than the optimal solution, but the final soil infestation is also lower.
2021_AMC-Tankam-etal_accepted.pdf (2.36 Mo) Télécharger le fichier
Licence : CC BY NC ND - Paternité - Pas d'utilisation commerciale - Pas de modification
hal-03111065 , version 1 (23-01-2023)
Copyright (Tous droits réservés)
Israël Tankam Chedjou, Frédéric Grognard, Jean Jules Tewa, Suzanne Touzeau. Optimal and sustainable management of a soilborne banana pest. Applied Mathematics and Computation, 2021, 397, pp.125883. ⟨10.1016/j.amc.2020.125883⟩. ⟨hal-03111065⟩
152 Consultations
25 Téléchargements
