A Discrete Domain Decomposition Method for Acoustics with Uniform Exponential Rate of Convergence Using Non-local Impedance Operators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2020
The relaxed Jacobi algorithm written at the continuous level was proven to converge exponentially. However, it was only a conjecture, hinted at by numerical experiments in [5, Section 8], that the discretized algorithm using finite elements has a rate of convergence uniformly bounded with respect to the discretization parameter
Fichier non déposé
hal-03118734 , version 1 (22-01-2021)
Xavier Claeys, Francis Collino, Patrick Joly, Emile Parolin. A Discrete Domain Decomposition Method for Acoustics with Uniform Exponential Rate of Convergence Using Non-local Impedance Operators. Domain Decomposition Methods in Science and Engineering XXV, pp.310-317, 2020, ⟨10.1007/978-3-030-56750-7_35⟩. ⟨hal-03118734⟩
47 Consultations
0 Téléchargements
