A Discrete Domain Decomposition Method for Acoustics with Uniform Exponential Rate of Convergence Using Non-local Impedance Operators
The relaxed Jacobi algorithm written at the continuous level was proven to converge exponentially. However, it was only a conjecture, hinted at by numerical experiments in [5, Section 8], that the discretized algorithm using finite elements has a rate of convergence uniformly bounded with respect to the discretization parameter
