A fast second-order discretization scheme for the linearized Green-Naghdi system with absorbing boundary conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2022
In this paper, we present a fully discrete second-order finite-difference scheme with fast evaluation of the convolution involved in the absorbing boundary conditions to solve the one-dimensional linearized Green-Naghdi system. The Padé expansion of the square-root function in the complex plane is used to implement the fast convolution. By introducing a constant damping parameter into the governing equations, the convergence analysis is developed when the damping term fulfills some conditions. In addition, the scheme is stable and leads to a highly reduced computational cost and low memory storage. A numerical example is provided to support the theoretical analysis and to illustrate the performance of the fast numerical scheme.
fastconvolutionfluidfinal.pdf (1.01 Mo) Télécharger le fichier
hal-03130074 , version 1 (03-02-2021)
Gang Pang, Songsong Ji, Xavier Antoine. A fast second-order discretization scheme for the linearized Green-Naghdi system with absorbing boundary conditions. ESAIM: Mathematical Modelling and Numerical Analysis, 2022, 56 (5), pp.1687-1714. ⟨10.1051/m2an/2022051⟩. ⟨hal-03130074⟩
65 Consultations
64 Téléchargements
