Derivative-free high-order uniformly accurate schemes for highly-oscillatory systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Numerical Analysis Année : 2022
In this paper, we address the computational aspects of uniformly accurate numerical methods for solving highly-oscillatory evolution equations. In particular, we introduce an approximation strategy that allows for the construction of arbitrary high-order methods using solely the right-hand side of the differential equation. No derivative of the vector field is required, while uniform accuracy is retained. The strategy is then applied to two different formulations of the problem, namely the two-scale and the micro-macro formulations. Numerical experiments on the Hénon-Heiles system, as well as on the Klein-Gordon equation and a Vlasov type problem all confirm the validity of the new strategy.
new_version_auto.pdf (547.14 Ko) Télécharger le fichier
hal-03141156 , version 1 (15-02-2021)
Philippe Chartier, Mohammed Lemou, Florian Méhats, Xiaofei Zhao. Derivative-free high-order uniformly accurate schemes for highly-oscillatory systems. IMA Journal of Numerical Analysis, 2022, ⟨10.1093/imanum/drab014⟩. ⟨hal-03141156⟩
101 Consultations
130 Téléchargements
