Incorporating transmission delays supported by diffusion MRI in MEG source reconstruction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
White matter fibers transfer the information between brain regions with delays that are measurable with magnetoencephalography and electroencephalography (M/EEG). In the context of regularizing the dynamics of M/EEG and recovering electrical activity of the brain from M/EEG measurements, this article proposes a graph representation-based framework to solve the M/EEG inverse problem, where prior information about transmission delays supported by diffusion MRI (dMRI) are included to enforce temporal smoothness. Results of the reconstruction of brain activity from simulated MEG measurements are compared to MNE, LORETA and CGS methods and we show that our approach improves MEG source localization when compared to these three state-of-theart approaches. In addition, we show preliminary qualitative results of the proposed reconstruction method on real MEG data for a sensory-motor task.
ISBI_2021_Ivana_Kojcic.pdf (3.14 Mo) Télécharger le fichier
hal-03143148 , version 1 (16-02-2021)
Ivana Kojčić, Théodore Papadopoulo, Rachid Deriche, Samuel Deslauriers-Gauthier. Incorporating transmission delays supported by diffusion MRI in MEG source reconstruction. ISBI 2021 - 18th IEEE International Symposium on Biomedical Imaging, Apr 2021, Nice, France. ⟨10.1109/ISBI48211.2021.9433861⟩. ⟨hal-03143148⟩
125 Consultations
282 Téléchargements
