Finite-size effects in response functions of molecular systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SMAI Journal of Computational Mathematics Année : 2022
We consider an electron in a localized potential submitted to a weak external, timedependent field. In the linear response regime, the response function can be computed using Kubo's formula. In this paper, we consider the numerical approximation of the response function by means of a truncation to a finite region of space. This is necessarily a singular approximation because of the discreteness of the spectrum of the truncated Hamiltonian, and in practice a regularization (smoothing) has to be used. Our results provide error estimates for the response function past the ionization threshold with respect to both the smoothing parameter and the size of the computational domain.
paper.pdf (393.3 Ko) Télécharger le fichier
hal-03145143 , version 1 (18-02-2021)
hal-03145143 , version 2 (03-12-2021)
Mi-Song Dupuy, Antoine Levitt. Finite-size effects in response functions of molecular systems. SMAI Journal of Computational Mathematics, 2022, 8, pp.273-294. ⟨10.5802/smai-jcm.87⟩. ⟨hal-03145143v2⟩
190 Consultations
194 Téléchargements
