A Hole in the Ladder: Interleaved Variables in Iterative Conditional Branching (Extended Version) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
The iterative conditional branchings appear in various sensitive algorithms, like the modular exponentiation in the RSA cryptosystem or the scalar multiplication in ellipticcurve cryptography. In this paper, we abstract away the desirable security properties achieved by the Montgomery ladder, and formalize systems of equations necessary to obtain what we call the semi-interleaved and fully-interleaved ladder properties. This fruitful approach allows us to design novel fault-injection attacks, able to obtain some/all bits of the secret against different ladders, including the common Montgomery ladder. We also demonstrate the generality of our approach by applying the ladder equations to the modular exponentiation and the scalar multiplication, both in the semi-and fully-interleaved cases, thus proposing novel and more secure algorithms.
article2.pdf (349.42 Ko) Télécharger le fichier
hal-03157804 , version 1 (05-03-2021)
hal-03157804 , version 2 (11-03-2024)
Yoann Marquer, Tania Richmond, Pascal Véron. A Hole in the Ladder: Interleaved Variables in Iterative Conditional Branching (Extended Version). 2021. ⟨hal-03157804v1⟩
146 Consultations
61 Téléchargements
