Interleaved Ladders: One more Step on Generalizing the Montgomery Ladder - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2024
Yoann Marquer
  • Fonction : Auteur
  • PersonId : 1362339
Tania Richmond
Pascal Véron
  • Fonction : Auteur
  • PersonId : 1092468
Iterative conditional branchings appear in various sensitive algorithms, like the modular exponentiation in the RSA cryptosystem or the scalar multiplication in elliptic-curve cryptography. The Montgomery ladder is a common example of such algorithm with desirable security properties against some side-channel and fault-injection attacks. In this paper, we abstract away and generalize these security properties by formalizing, using systems of equations, what we call semi-interleaved and fully-interleaved ladders. This fruitful approach allows us to design novel fault-injection attacks, able to obtain some/all bits of the secret against different ladders, breaking the common Montgomery ladder. We also demonstrate the generality of our approach by applying our ladder equations to the modular exponentiation and the scalar multiplication, both in the semi- and fully-interleaved cases, to propose novel and more secure algorithms.
ladderLong2.pdf (559.18 Ko) Télécharger le fichier
Licence : CC BY - Paternité
hal-03157804 , version 1 (05-03-2021)
hal-03157804 , version 2 (11-03-2024)
Yoann Marquer, Tania Richmond, Pascal Véron. Interleaved Ladders: One more Step on Generalizing the Montgomery Ladder. 2024. ⟨hal-03157804v2⟩
Collections
UNIV-TLN IMATH UNC
128 Consultations
54 Téléchargements
