A mathematical study of a hyperbolic metamaterial in free space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Mathematical Analysis Année : 2022
Wave propagation in hyperbolic metamaterials is described by the Maxwell equations with a frequency dependent tensor of dielectric permittivity, whose eigenvalues are of different signs. In this case the problem becomes hyperbolic (Klein-Gordon equation) for a certain range of frequencies. The principal theoretical and numerical difficulty comes from the fact that this hyperbolic equation is posed in a free space, without initial conditions provided. The subject of the work is the theoretical justification of this problem. In particular, this includes the construction of a radiation condition, a well-posedness result, a limiting absorption principle and regularity estimates on the solution.
report.pdf (3.33 Mo) Télécharger le fichier
hal-03164619 , version 1 (10-03-2021)
Patrick Ciarlet, Maryna Kachanovska. A mathematical study of a hyperbolic metamaterial in free space. SIAM Journal on Mathematical Analysis, 2022, 54 (2), pp.2216-2250. ⟨10.1137/21M1404223⟩. ⟨hal-03164619⟩
167 Consultations
146 Téléchargements
