A mechanically consistent model for fluid-structure interactions with contact including seepage - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Methods in Applied Mechanics and Engineering Année : 2022
We present a new approach for the mechanically consistent modelling and simulation of fluid-structure interactions with contact. The fundamental idea consists of combining a relaxed contact formulation with the modelling of seepage through a porous layer of co-dimension 1 during contact. For the latter, a Darcy model is considered in a thin porous layer attached to a solid boundary in the limit of infinitesimal thickness. In combination with a relaxation of the contact conditions the computational model is both mechanically consistent and simple to implement. We analyse the approach in detailed numerical studies with both thick-and thin-walled solids, within a fully Eulerian and an immersed approach for the fluid-structure interaction and using fitted and unfitted finite element discretisations.
BurmanFernandezFreiGerosa.pdf (4.28 Mo) Télécharger le fichier
hal-03174087 , version 1 (18-03-2021)
Stefan Frei, Fannie Gerosa, Erik Burman, Miguel Angel Fernández. A mechanically consistent model for fluid-structure interactions with contact including seepage. Computer Methods in Applied Mechanics and Engineering, 2022, 392, pp.114637. ⟨10.1016/j.cma.2022.114637⟩. ⟨hal-03174087⟩
180 Consultations
144 Téléchargements
