Computational details for : "Differential Dynamic Programming for Maximum a Posteriori Centroidal State Estimation of Legged Robots" - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2021
This document complements the paper entitled "Differential Dynamic Programming for Maximum a Posteriori Centroidal State Estimation of Legged Robots" [1]. The purpose of this work was to estimate the centroidal dynamics of legged robots by formulating a maximum a posteriori problem and solving it thanks to differential dynamic programming (DDP).
technical_report.pdf (186.56 Ko) Télécharger le fichier
hal-03180052 , version 1 (24-03-2021)
hal-03180052 , version 2 (25-03-2021)
hal-03180052 , version 3 (25-03-2021)
hal-03180052 , version 4 (25-03-2021)
  • HAL Id : hal-03180052 , version 1
François Bailly, Justin Carpentier, Philippe Souères. Computational details for : "Differential Dynamic Programming for Maximum a Posteriori Centroidal State Estimation of Legged Robots". [Research Report] LAAS-CNRS; Université de Montréal. 2021. ⟨hal-03180052v1⟩
187 Consultations
96 Téléchargements
