Internal Model Controller to Attenuate Periodic Disturbance of a First-Order Time-Delay System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A controller design based on the internal model control principle is introduced as an alternative to the repetitive control structure to attenuate the periodic disturbance. Such a disturbance phenomenon is observed for example in hot rolling mills due to roll eccentricity and is considered here as a motivation example. The emphasis is on the analytic design of the filter and on the time-delay parameter within the controller. By these two components, the controller action is tuned to achieve a zero gain and synchronized time shift to compensate completely the periodic disturbance. The overall procedure is validated by simulations on a model identified from real process data.
ECC21_0493_FI.pdf (1021.19 Ko) Télécharger le fichier
hal-03208699 , version 1 (26-04-2021)
Can Kutlu Yuksel, Jaroslav Busek, Silviu-Iulian Niculescu, Tomas Vyhlidal. Internal Model Controller to Attenuate Periodic Disturbance of a First-Order Time-Delay System. ECC 2021 - European Control Conference, Jun 2021, Rotterdam / Virtual, Netherlands. ⟨10.23919/ecc54610.2021.9655202⟩. ⟨hal-03208699⟩
120 Consultations
76 Téléchargements
