HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
De Bruijn and Kautz Bus networks
Jean-Claude Bermond 1 Robin Dawes 2 Fahir Ö. Ergincan 2
1 SLOOP - Simulation, Object Oriented Languages and Parallelism
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - COMRED - COMmunications, Réseaux, systèmes Embarqués et Distribués
Abstract : Our aim was to find bus interconnection networks which connect as many processors as possible, for given upper bounds on the number of connections per processor, the number of processors per bus, and the network diameter. Point‐to‐point networks are a special case of bus networks in which every bus connects only two processors. In this case, de Bruijn and Kautz networks and their generalizations are known to be among the best families of networks with respect to the aforementioned criteria. In this paper, we present the directed de Bruijn bus networks, which connect two or more processors on a bus and contain the point‐to‐point de Bruijn networks and their generalization as a special case. We study two different schemes of the directed de Bruijn bus networks. We also show that the directed Kautz bus networks can be defined in the same manner.
Complete list of metadata
https://hal.inria.fr/hal-03210219
Contributor : Jean-Claude Bermond Connect in order to contact the contributor
Submitted on : Tuesday, April 27, 2021 - 6:35:29 PM
Last modification on : Friday, February 4, 2022 - 3:08:47 AM
File
98-BDE97-debruijn-bus-networks...
Identifiers
Collections
Citation
Jean-Claude Bermond, Robin Dawes, Fahir Ö. Ergincan. De Bruijn and Kautz Bus networks. Networks, Wiley, 1997, 30 (3), pp.205-218. ⟨10.1002/(SICI)1097-0037(199710)30:3<205::AID-NET5>3.0.CO;2-P⟩. ⟨hal-03210219⟩
Share
Metrics
Record views
14
Files downloads
49
