De Bruijn and Kautz Bus networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Networks Année : 1997
Our aim was to find bus interconnection networks which connect as many processors as possible, for given upper bounds on the number of connections per processor, the number of processors per bus, and the network diameter. Point‐to‐point networks are a special case of bus networks in which every bus connects only two processors. In this case, de Bruijn and Kautz networks and their generalizations are known to be among the best families of networks with respect to the aforementioned criteria. In this paper, we present the directed de Bruijn bus networks, which connect two or more processors on a bus and contain the point‐to‐point de Bruijn networks and their generalization as a special case. We study two different schemes of the directed de Bruijn bus networks. We also show that the directed Kautz bus networks can be defined in the same manner.
98-BDE97-debruijn-bus-networks.pdf (4.72 Mo) Télécharger le fichier
hal-03210219 , version 1 (27-04-2021)
Jean-Claude Bermond, Robin Dawes, Fahir Ö. Ergincan. De Bruijn and Kautz Bus networks. Networks, 1997, 30 (3), pp.205-218. ⟨10.1002/(SICI)1097-0037(199710)30:3<205::AID-NET5>3.0.CO;2-P⟩. ⟨hal-03210219⟩
23 Consultations
75 Téléchargements
