Propagation of singularities for subelliptic wave equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Hörmander's propagation of singularities theorem does not fully describe the propagation of singularities in subelliptic wave equations, due to the existence of doubly characteristic points. In the present paper, building upon a visionary conference paper by R. Melrose \cite{Mel86}, we prove that singularities of subelliptic wave equations only propagate along null-bicharacteristics and abnormal extremal lifts of singular curves, which are well-known curves in optimal control theory. We first revisit in depth the ideas sketched by R. Melrose in \cite{Mel86}, notably providing a full proof of its main statement. Making more explicit computations, we then explain how sub-Riemannian geometry and abnormal extremals come into play. This result shows that abnormal extremals have an important role in the classical-quantum correspondence between sub-Riemannian geometry and subelliptic operators. As a consequence, for $x\neq y$ and denoting by $K_G$ the wave kernel, we obtain that the singular support of the distribution $t\mapsto K_G(t,x,y)$ is included in the set of lengths of the normal geodesics joining $x$ and $y$, at least up to the time equal to the minimal length of a singular curve joining $x$ and $y$.
Melrose mysterious paper v16.pdf (700.04 Ko) Télécharger le fichier
hal-03259054 , version 1 (14-06-2021)
hal-03259054 , version 2 (09-12-2021)
hal-03259054 , version 3 (07-05-2022)
Cyril Letrouit. Propagation of singularities for subelliptic wave equations. 2021. ⟨hal-03259054v2⟩
78 Consultations
253 Téléchargements
