Propagation of singularities for subelliptic wave equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Mathematical Physics Année : 2022
Hörmander's propagation of singularities theorem does not fully describe the propagation of singularities in subelliptic wave equations, due to the existence of doubly characteristic points. In the present work, building upon a visionary conference paper by R. Melrose \cite{Mel86}, we prove that singularities of subelliptic wave equations only propagate along null-bicharacteristics and abnormal extremals, which are well-known curves in optimal control theory. As a consequence, we characterize the singular support of subelliptic wave kernels outside the diagonal. These results show that abnormal extremals play an important role in the classical-quantum correspondence between sub-Riemannian geometry and sub-Laplacians.
Melrose mysterious paper v18.pdf (690.5 Ko) Télécharger le fichier
hal-03259054 , version 1 (14-06-2021)
hal-03259054 , version 2 (09-12-2021)
hal-03259054 , version 3 (07-05-2022)
Cyril Letrouit. Propagation of singularities for subelliptic wave equations. Communications in Mathematical Physics, In press, ⟨10.48550/arXiv.2106.07216⟩. ⟨hal-03259054v3⟩
78 Consultations
253 Téléchargements
