EPR imaging of sinapyl alcohol and its application to the study of plant cell wall lignification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Chemical Communications Année : 2021
Bioorthogonal chemical reporter strategy can be successfully combined with EPR spectroscopy in plant tissues to detect the incorporation of a tagged monolignol into the lignin polymer.
Simon et al. - 2021 - EPR imaging of sinapyl alcohol and its application to the study of plant cell wall lignification.pdf (1.84 Mo) Télécharger le fichier
P21.10 Correction EPR imaging of .pdf (1.27 Mo) Télécharger le fichier
hal-03269713 , version 1 (24-06-2021)
hal-03269713 , version 2 (18-10-2021)
Paternité - Pas d'utilisation commerciale
Clémence Simon, Cedric Lion, Hania Ahouari, Hervé Vezin, Simon Hawkins, et al.. EPR imaging of sinapyl alcohol and its application to the study of plant cell wall lignification. Chemical Communications, 2021, Chemical Communications, 57 (3), pp.387-390. ⟨10.1039/d0cc05218c⟩. ⟨hal-03269713v2⟩
56 Consultations
76 Téléchargements
