On analysis of Persidskii systems and their implementations using LMIs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2021
The conditions of (integral) input-to-state stability and input-output-to-state stability are established for a class of generalized Persidskii systems. The proposed conditions are formulated using linear matrix inequalities. Based on these results the conditions of convergence are derived for discretizations of this class of models obtained by the explicit and the implicit Euler methods. The proposed theory is finally applied to design a robust stabilization control.
Persidskij_J.pdf (656.52 Ko) Télécharger le fichier
hal-03291855 , version 1 (19-07-2021)
  • HAL Id : hal-03291855 , version 1
Denis Efimov, Alexander Aleksandrov. On analysis of Persidskii systems and their implementations using LMIs. Automatica, inPress. ⟨hal-03291855⟩
46 Consultations
106 Téléchargements
