Robust output feedback model predictive control for constrained linear systems via interval observers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2021
This work addresses the problem of robust output feedback model predictive control for discrete-time, constrained linear systems corrupted by (bounded) state and measurement disturbances. Using the available information on measurements and uncertainty bounds, the objective is to stabilize such a system while robustly respecting the imposed constraints on state and control. To this end, interval observer and predictor with guaranteed performance are incorporated into the classic MPC scheme. This new approach offers advantages such as enlarged feasible regions for the optimal control problem, low computational burden, and ease of design.
Linear_IOMPC.pdf (567.39 Ko) Télécharger le fichier
hal-03297175 , version 1 (23-07-2021)
Alex Reis de Souza, Denis Efimov, Tarek Raïssi, Xubin Ping, Alex dos Reis de Souza. Robust output feedback model predictive control for constrained linear systems via interval observers. Automatica, 2021, 135, pp.109951. ⟨10.1016/j.automatica.2021.109951⟩. ⟨hal-03297175⟩
187 Consultations
321 Téléchargements
