On the sensitivity of structural turbulence uncertainty estimates to time and space resolution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computers and Fluids Année : 2021
This paper presents a sensitivity analysis of structural turbulence uncertainty estimates to time and space resolution of numerical computations. Turbulence uncertainty estimates are obtained by means of the Eigenspace Perturbation Method (EPM). Results show that, in general, one can not expect the turbulence uncertainty estimates to be mesh and time-step independent based on the sole sensitivity analysis of the baseline solution. The recommendation is to carry out independent sensitivity studies, to guarantee that the confidence uncertainty estimates are well-predicted regardless of the space and time resolution.
journal_pre_proof.pdf (3.88 Mo) Télécharger le fichier
hal-03299149 , version 1 (26-07-2021)
Giulio Gori, O P Le Maître, P M Congedo. On the sensitivity of structural turbulence uncertainty estimates to time and space resolution. Computers and Fluids, inPress, ⟨10.1016/j.compfluid.2021.105081⟩. ⟨hal-03299149⟩
58 Consultations
18 Téléchargements
