Control for synchronization of bistable piecewise affine genetic regulatory networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we study the diffusive coupling of a network of identical bistable switch piecewise-affine systems. We propose a control strategy which synchronizes every bistable switch subsystem of the network towards the same steady state.
chaos_1.pdf (852.13 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-03317956 , version 1 (08-08-2021)
Nicolas Augier, Madalena Chaves, Jean-Luc Gouzé. Control for synchronization of bistable piecewise affine genetic regulatory networks. CHAOS 2021 - 6th IFAC Hybrid Conference on Analysis and Control of Chaotic Systems, Sep 2021, Catania, Italy. ⟨10.1016/j.ifacol.2021.11.044⟩. ⟨hal-03317956⟩
87 Consultations
133 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
