A Reduced Index Mode-Independent Structure Model Transformation for Multimode Modelica Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Since its 3.3 release, Modelica offers the possibility to specify models of dynamical systems with multiple modes having different DAE-based dynamics. However, the handling of such models by the current Modelica tools is not satisfactory, with mathematically sound models yielding exceptions at runtime. In this article, we propose a systematic way of rewriting a multimode Modelica model, based on the results of an already implemented multimode structural analysis. The rewritten Modelica model is guaranteed to be correctly compiled by state-of-the-art Modelica tools. Simulation results are presented on a simple, yet meaningful, physical system whose original Modelica model is not correctly handled by state-of-the-art Modelica tools.
Modelica2021_RIMIS.pdf (598.98 Ko) Télécharger le fichier
hal-03320499 , version 1 (16-08-2021)
Paternité
  • HAL Id : hal-03320499 , version 1
Benoît Caillaud, Mathias Malandain, Albert Benveniste. A Reduced Index Mode-Independent Structure Model Transformation for Multimode Modelica Models. MODELICA 2021 - 14th International Modelica Conference, Sep 2021, Linköping, Sweden. pp.1-11. ⟨hal-03320499⟩
84 Consultations
100 Téléchargements
